[gdal-dev] netcdf option build error
Jeshua Lacock
jeshua at OpenOSX.com
Tue Apr 29 17:20:58 EDT 2008
On Apr 29, 2008, at 2:39 PM, William Kyngesburye wrote:
> You should probably add __i386__ to the define tests here.
I am not sure if I fully understand, should I add to line 66:
&& !defined(__i386__)
Or if that is not correct, can you email me a patch?
>>> I don't know if this is enough to affect the definition of
>>> MAX_VAR_DIMS or not. I do see that MAX_VAR_DIMS is a backward-
>>> compatibility define for Netcdf v2 - netcdf.h lines 912+. The
>>> modern version is NC_MAX_VAR_DIMS. Did you use --disable-v2 when
>>> configuring netcdf?
>> No I did not try disable-v2, do you think I should?
> No - the GDAL HDF4 driver is expecting the v2 name.
Ah; I see, thanks!
>> Thanks for your help - if you are interested, I would be happy to
>> pay you to SSH in and take a look...
> It's a hobby for me. And all I can offer is what I've found that
> works for me, I don't know if poking around in your setup will help.
> Note: I've been *slowly* updating my build instructions on my site,
> but I haven't gotten to the GIS stuff yet. Here's a quick-n-dirty
> summary of the relevant bits to your problem (assuming everything
> needed in /usr/local, otherwise a lot of --with options needed):
> - netcdf
> ./configure --disable-f77 --disable-cxx --disable-examples --disable-
> dependency-tracking --disable-utilities
> - HDF4 4.2r2
> hconv.h: apply the endian patch
> ./configure --disable-fortran --disable-dependency-tracking --
> disable-netcdf
> - GDAL (fill in other options you need):
> ./configure --with-threads --without-grass --with-netcdf=/usr/local
> --with-hdf4=/usr/local
Thanks, I was not disabling most of those options, so I will try now...
Thanks again,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
