[gdal-dev] GDALDataset limits?
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 1 09:56:03 EDT 2008
Patrick Cannon wrote:
> Hi Frank,
> Is there a limit to the number of GDALDatasets that can be open at one time?
> My program is set to automatically open raster images from a database.
> There are over 2254 charts in the database. Each record has the path to
> the actual file on disk.
> In auto mode it gets to around 1004 or so files and then GDAL starts
> returning "file not found" errors.
Patrick,
My first guess would be a file handle limit, as others have mentioned.
> If I manually open the files it says can not be found, it opens them
> without issue.
I'm afraid I don't understand this. The "says it can not be found"
and "opens them without issue" parts of this sentance seem to conflict.
> So the file is available on
> disk. Also, if I change the sort on the database so it loads from the
> bottom it has no problem opening the files in auto mode.
You are saying that you can open at 2254 charts fine if you open them in
a different order than the default? That is odd behavior!
At this point I'd normally try running in the debugger to track down
the failure, and/or running things under something like valgrind.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
