[gdal-dev] GDALDataset limits?
Mateusz Loskot mateusz at loskot.net
Fri Aug 1 10:08:50 EDT 2008
Frank Warmerdam wrote:
> At this point I'd normally try running in the debugger to track down
> the failure, and/or running things under something like valgrind.
If Patrick uses POSIX system, then I'd try to write a test program
and monitor errno value if it's gets set to EMFILE [1]
[1]
http://www.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_03.html#tag_02_03
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
