[Gdal-dev] GDAL OGR2OGR does not export Oracle Views
Dejan Gregor
eloquence2 at gmail.com
Thu Aug 7 03:18:33 EDT 2008
Hi Mateusz,
thanks for your reply. I have ran the command and got a response:
C:\>ogrinfo "OCI:maribor/admin at ORCL:MARIBOR.WA_PIPE_VIEW"
ERROR 1: ORA-04043: object MARIBOR.WA_PIPE_VIEW does not exist in
OCIDescribeAny
INFO: Open of `OCI:maribor/admin at ORCL:MARIBOR.WA_PIPE_VIEW'
using driver `OCI' successful.
1: MARIBOR.WA_PIPE_VIEW
However, the export into an ESRI Shapefile works fine, I didn't see that
although the error message occured (probably because of the missing metadata
in MDSYS), it exported the ESRI Shapefile perfectly.
I think it is not a bug.
Thanks!
Dejan
View this message in context: http://www.nabble.com/GDAL-OGR2OGR-does-not-export-Oracle-Views-tp18850008p18865340.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
