[Gdal-dev] GDAL OGR2OGR does not export Oracle Views
Mateusz Loskot
mateusz at loskot.net
Thu Aug 7 10:50:29 EDT 2008
Dejan Gregor wrote:
> Hi Mateusz,
> thanks for your reply. I have ran the command and got a response:
> C:\>ogrinfo "OCI:maribor/admin at ORCL:MARIBOR.WA_PIPE_VIEW"
> ERROR 1: ORA-04043: object MARIBOR.WA_PIPE_VIEW does not exist in
> OCIDescribeAny
> INFO: Open of `OCI:maribor/admin at ORCL:MARIBOR.WA_PIPE_VIEW'
> using driver `OCI' successful.
> 1: MARIBOR.WA_PIPE_VIEW
> However, the export into an ESRI Shapefile works fine, I didn't see that
> although the error message occured (probably because of the missing metadata
> in MDSYS), it exported the ESRI Shapefile perfectly.
Dejan,
Good it's working!
> I think it is not a bug.
OK. Seems like inaccurate message only.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
