[gdal-dev] How to read GRIB2 fommat data
Thu Aug 7 12:35:20 EDT 2008
Limei Ran wrote:
> Hi:
> GRIB is a format listed in the GDAL supported formats.  But, I  get the
> following error message when I used gdalinfo.
> gdalinfo goes_rtv_CALB_200608051145Z.grid
> ERROR 4: `goes_rtv_CALB_200608051145Z.grid' does not exist in the file
> system,
> and is not recognised as a supported dataset name.
> gdalinfo failed - unable to open 'goes_rtv_CALB_200608051145Z.grid'.
> I believe that my file is GRIB2 format.  What should I do to have GRIB
> format in my compiled GDAL?
Limei,
What version of GDAL are you using?  The GRIB driver evolved a fair amount
this year.  It might be helpful if you could make your file available
so I could test with it.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
