[gdal-dev] Re: The world is flipped redux
Roger André
randre at gmail.com
Fri Aug 8 19:51:30 EDT 2008
My apologies to Matt, the flip_raster.py does flip something, as when I
compare the images in OpenEV, I can see that they are reversed. But when I
compare their corner coords with gdalinfo, they appear identical.
$ gdalinfo test.tif
<snip>
Corner Coordinates:
Upper Left ( -71.3600000, -23.5000000)
Lower Left ( -71.3600000, -8.5000000)
Upper Right ( -55.7000000, -23.5000000)
Lower Right ( -55.7000000, -8.5000000)
$ gdalinfo bolivia_fullres.tif
<snip>
Corner Coordinates:
My head hurts.
On Fri, Aug 8, 2008 at 4:24 PM, Roger André <randre at gmail.com> wrote:
> Ok, this is driving me nuts, I can't handle "South is up" anymore. I have
> NetCDF derived GMT grids which have a flipped y-axis. This makes for
> georeferencing that looks like this:
> Corner Coordinates:
> Upper Left ( -90.0000000, -90.0000000)
> Lower Left ( -90.0000000, 0.0000000)
> Upper Right ( 0.0000000, -90.0000000)
> Lower Right ( 0.0000000, 0.0000000)
> I've seen some old discussions about this, but haven't really found a good
> solution. I've tried a "flip_raster.py" utility that Matt Perry wrote, but
> it doesn't seem to do anything with my data. (probably due to my crappy
> data, not Matt's tool) I've also read that there have been some rewrites of
> the NetCDF driver that are supposed to be able to deal with this, but I'm
> not sure about that.
> How have others out there dealt with this issue? I'd like to be able to
> convert the grids into GeoTIFF's and have the TIFF's be "right" side up.
> Thanks,
> Flipped-off Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080808/f98a7dff/attachment.html
