[gdal-dev] orginfo and prj files
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Aug 14 11:02:58 EDT 2008
Hi there,
Correct if I am wrong.
If there is a .PRJ file associated with a .SHP, ogrinfo will just print
out the content of the .PRJ. Ex.:
D:\Data\ESRIDATA\USA> ogrinfo -so states.shp states
INFO: Open of `states.shp'
       using driver `ESRI Shapefile' successful.
Layer name: states
Geometry: Polygon
Feature Count: 51
Extent: (-178.217598, 18.924782) - (-66.969271, 71.406235)
Layer SRS WKT:
GEOGCS["GCS_North_American_1983",
     DATUM["North_American_Datum_1983",
         SPHEROID["GRS_1980",6378137,298.257222101]],
     PRIMEM["Greenwich",0],
     UNIT["Degree",0.0174532925199433]]
It will not going to run "OGRImportFromESRI()" to get EPSG Authority
codes. Isn't it right?
Thanks in advance for any help.
Ivan
