[gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on netcdf data
Maarten Plieger plieger at knmi.nl
Fri Aug 15 07:43:28 EDT 2008
Hi Vishal,
I do not have any problems with the gdal netcdf driver...
The example netcdf files from the unidata website work well for example.
I am using GDAL 1.5.2 with the latest netcdf 4.0 library.
Maarten
Vishal Mehta schreef:
> Hi Frank,
> I have tried with 2 netcdf files from different sites - same error 'segmentation fault'
> the first was 60mb, the second was small !260kb.
> does anyone in the list have this problem with gdal and netcdf data? earlier posts seemed to suggest a conflict between netcdf and hdf4, but i did not compile with hdf support so that shouldnt be a problem i thought..
> thanks,
> vishal
> __________________
> From: fwarmerdam at gmail.com [fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
> Sent: Thursday, August 14, 2008 11:12 AM
> To: Vishal Mehta
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on netcdf data
> On Thu, Aug 14, 2008 at 12:42 PM, Vishal Mehta <vishal.mehta at sei-us.org> wrote:
>> 2. I compiled from source gdal1.5.2 from
>> http://trac.osgeo.org/gdal/wiki/DownloadSource
>> using the following configure
>> ./configure --with-netcdf=/usr/lib --with-libtiff=yes --with-geotiff=yes --with-jpeg=/usr/lib --with-gif=/usr/lib --with-png=/ur/lib --with-pg=/usr/bin/pg_config --with-libgrass=yes
>> make
>> sudo make install
>> and made sure the libgdal link was referring to the new one.
>> I tried
>> gdalinfo file.nc
>> and again got 'segmentation fault'
>> it works for other data types; only netcdf does not work (just like before with gdal1.4.4)
> Vishal,
> Have you tried with other netcdf files?  How big is "big"?   Perhaps
> you are encounter a 2GB file size limit?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.6.3/1611 - Release Date: 8/14/2008 6:20 AM
> gdal-dev mailing list
Maarten Plieger
KNMI, R&D Information and Observation Technology, De Bilt
(t) +31 30 2206330
