[gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on
netcdf data
Vishal Mehta
vishal.mehta at sei-us.org
Thu Aug 14 18:35:05 EDT 2008
Hi Frank,
I have tried with 2 netcdf files from different sites - same error 'segmentation fault'
the first was 60mb, the second was small !260kb.
does anyone in the list have this problem with gdal and netcdf data? earlier posts seemed to suggest a conflict between netcdf and hdf4, but i did not compile with hdf support so that shouldnt be a problem i thought..
thanks,
vishal
__________________
From: fwarmerdam at gmail.com [fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
Sent: Thursday, August 14, 2008 11:12 AM
To: Vishal Mehta
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on netcdf data
On Thu, Aug 14, 2008 at 12:42 PM, Vishal Mehta <vishal.mehta at sei-us.org> wrote:
> 2. I compiled from source gdal1.5.2 from
> http://trac.osgeo.org/gdal/wiki/DownloadSource
> using the following configure
> ./configure --with-netcdf=/usr/lib --with-libtiff=yes --with-geotiff=yes --with-jpeg=/usr/lib --with-gif=/usr/lib --with-png=/ur/lib --with-pg=/usr/bin/pg_config --with-libgrass=yes
> make
> sudo make install
> and made sure the libgdal link was referring to the new one.
> I tried
> gdalinfo file.nc
> and again got 'segmentation fault'
> it works for other data types; only netcdf does not work (just like before with gdal1.4.4)
Vishal,
Have you tried with other netcdf files? How big is "big"? Perhaps
you are encounter a 2GB file size limit?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.6.3/1611 - Release Date: 8/14/2008 6:20 AM
