[Gdal-dev] GTiff / gdal_translate / CMYK - problem
Maksim Sestic
max at geoinova.com
Wed Aug 20 05:46:06 EDT 2008
Hi all,
I'm having troubles with gdal_translate while creating uncompressed 3-band
GTiff with CMYK photometric representation. Well, at least CMYK
representation recognized by Photoshop, which is
PhotometricInterpretation=5. If I use recommended gdal_translate -co
'PHOTOMETRIC=CMYK' switch I keep getting "grayscale" (!) result, again,
that's what Photoshop says (PhotometricInterpretation=1).
What other -co parameters should I set to make it work? I'm using
gdal_translate from FWTools 2.2.3
Here's the gdalinfo reports:
1) For RGB raster parsed with gdal_translate -co 'PHOTOMETRIC=CMYK'
switch:
Size is 945, 945
Coordinate System is `'
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=MyApp
TIFFTAG_DATETIME=20.08.2008 02:51:37
TIFFTAG_XRESOLUTION=240
TIFFTAG_YRESOLUTION=240
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 945.0)
Upper Right ( 945.0, 0.0)
Lower Right ( 945.0, 945.0)
Center ( 472.5, 472.5)
Band 1 Block=945x2 Type=Byte, ColorInterp=Gray
Band 2 Block=945x2 Type=Byte, ColorInterp=Undefined
Band 3 Block=945x2 Type=Byte, ColorInterp=Undefined
Side note: I also tried using -co 'PHOTOMETRIC=YCBCR' and
'PHOTOMETRIC=CIELAB'switches but then gdal_translate crashes.
2) Photoshopped tiff with CMYK mode set (that's what I need to get):
Driver: GTiff/GeoTIFF
Files: 080417_75008_000000017_CMYK.tif
Size is 945, 945
Metadata:
TIFFTAG_SOFTWARE=Adobe Photoshop CS3 Windows
TIFFTAG_DATETIME=2008:08:20 02:21:08
INTERLEAVE=PIXEL
Corner Coordinates:
Band 1 Block=945x2 Type=Byte, ColorInterp=Undefined
Band 4 Block=945x2 Type=Byte, ColorInterp=Undefined
Also, there's another Photoshop's TIFF tag, "NativeDigest", which I don't
really get (it's not recognized by gdalinfo) - here's the xmp output:
<tiff:NativeDigest
xmlns:tiff="http://ns.adobe.com/tiff/1.0/">256,257,258,259,262,274,277,284,530,531,282,283,296,301,318,319,529,532,306,270,271,272,305,315,33432;46BB973B26CC7DED3A1C59F8F9AC7EC5</tiff:NativeDigest>
Regards,
Maksim Sestic
View this message in context: http://www.nabble.com/GTiff---gdal_translate---CMYK---problem-tp19066003p19066003.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
