[gdal-dev] netcdf driver
Christopher Condit condit at sdsc.edu
Thu Aug 21 15:19:12 EDT 2008
Hi Denis-
I put this patch in a few months ago addressing this libdap 3.8 issue:
http://trac.osgeo.org/gdal/ticket/2404
This will get the code to build against libdap3.8 (primarily a namespace
problem), but there are still issues accessing DODS datasources:
http://trac.osgeo.org/gdal/ticket/2492
If you get some time to look into this it would be great...
Thanks,
-Chris
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Denis Nadeau
Sent: Thursday, August 21, 2008 10:53 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] netcdf driver
I will being doing some new development on netCDF driver to make it more
CF-1 Compliant.
Note: when I compiled the netCDF 3.6.2  with HDF4.2r3 (with the flag
--disable-netcdf)  I had to change all macros such as "MAX_NC_NAME" to
"H4_MAX_NC_NAME" and many other similar macros. Need to do some testing
on this.
I also noticed that DODS (dodsdataset2.cpp) does not seem to compile
with libdap3.8.2.  There are some major changes in the library for C++.
I will take a look into this as well, but do not promess anything...
If you have suggestion of improvements for DODS, HDF4 and netCDF
drivers, let me know, I have a little bit of time this coming month.
Regards,
Denis
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080821/d4ddccc0/attachment.html
