[gdal-dev] netcdf driver
Denis Nadeau
denis.nadeau at gmail.com
Thu Aug 21 13:53:04 EDT 2008
I will being doing some new development on netCDF driver to make it more
CF-1 Compliant.
Note: when I compiled the netCDF 3.6.2 with HDF4.2r3 (with the flag
--disable-netcdf) I had to change all macros such as "MAX_NC_NAME" to
"H4_MAX_NC_NAME" and many other similar macros. Need to do some testing on
this.
I also noticed that DODS (dodsdataset2.cpp) does not seem to compile with
libdap3.8.2. There are some major changes in the library for C++.
I will take a look into this as well, but do not promess anything...
If you have suggestion of improvements for DODS, HDF4 and netCDF drivers,
let me know, I have a little bit of time this coming month.
Regards,
Denis
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080821/920dbed4/attachment.html
