[gdal-dev] geotiff image problem
Silvia Marchesi silviamarchesi at gmail.com
Thu Aug 28 11:27:22 EDT 2008
Thanks a lot,!
Now I can compile, but when I try to run the program a message appears:
"This application has failed to start because gdal15d-vc8 was not found.
Re-installing the application may fix the problem"
I have checked and in the folder I have downloaded (pre-installed
gdal151-vc8) there are only gdal_id-vc8.lib and gdal_i-vc8.lib.
Best regards,
Silvia
2008/8/28 <mchapman at fortifieddatacom.com>
> Silvia,
> In your project properties in vs under the "Link" tab you need to add the
> path to the file "gdal_i.lib".
> Martin
> Sent via BlackBerry by AT&T
> -----Original Message-----
> From: "Silvia Marchesi" <silviamarchesi at gmail.com>
> Date: Thu, 28 Aug 2008 16:30:25
> To: <gdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] geotiff image problem
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080828/f1bab835/attachment.html
