[gdal-dev] geotiff image problem
Silvia Marchesi
silviamarchesi at gmail.com
Thu Aug 28 11:41:49 EDT 2008
Sorry for my last post.. I have made a bit of confusion! In the folder 'bin'
I have found the missed .dll, however I can't understand why does it not
find it.
Silvia
2008/8/28 Silvia Marchesi <silviamarchesi at gmail.com>
> Thanks a lot,!
> Now I can compile, but when I try to run the program a message appears:
> "This application has failed to start because gdal15d-vc8 was not found.
> Re-installing the application may fix the problem"
> I have checked and in the folder I have downloaded (pre-installed
> gdal151-vc8) there are only gdal_id-vc8.lib and gdal_i-vc8.lib.
> Best regards,
> Silvia
> 2008/8/28 <mchapman at fortifieddatacom.com>
> Silvia,
>> In your project properties in vs under the "Link" tab you need to add the
>> path to the file "gdal_i.lib".
>> Martin
>> Sent via BlackBerry by AT&T
>> -----Original Message-----
>> From: "Silvia Marchesi" <silviamarchesi at gmail.com>
>> Date: Thu, 28 Aug 2008 16:30:25
>> To: <gdal-dev at lists.osgeo.org>
>> Subject: [gdal-dev] geotiff image problem
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080828/128983b8/attachment.html
