[gdal-dev] geotiff image problem
Mateusz Loskot mateusz at loskot.net
Thu Aug 28 16:35:44 EDT 2008
Silvia Marchesi wrote:
> Thanks a lot,
>  now the problem is with libpng13-vc8, but I think I'll read the suggested
> instructions from gdal website..
Silvia,
You need to make all GDAL DLL binaries and all GDAL DLL dependencies
"visible" to dynamic linker.
Each time your program is launched, dynamic loader tries to find DLL
libraries your program uses.
Here you can find information where the loader searches for DLL and in
what order, so it will suggest you where to put GDAL and other DLL files.
http://msdn.microsoft.com/en-us/library/ms682586.aspx
If some DLLs still can not be found, try to use dependency walker to
find out what DLLs are missing:
http://www.dependencywalker.com/
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
