[gdal-dev] geotiff image problem
Silvia Marchesi
silviamarchesi at gmail.com
Thu Aug 28 12:20:17 EDT 2008
Thanks a lot,
now the problem is with libpng13-vc8, but I think I'll read the suggested
instructions from gdal website..
Silvia
2008/8/28 Martin Chapman <mchapman at fortifieddatacom.com>
> Silvia,
> The d in gdal15d-vc8 means debug version. Run your IDE in release mode
> and make sure the .dll file is in the same directory as your application
> .exe. If you want to use the dll in debug mode, my suggestion is to get the
> source code via SVN and compile it locally. It's really easy to do if you
> read the Windows build instructions on the gdal.org website.
> Martin
> *From:* Silvia Marchesi [mailto:silviamarchesi at gmail.com]
> *Sent:* Thursday, August 28, 2008 9:42 AM
> *To:* mchapman at fortifieddatacom.com
> *Cc:* gdal-dev-bounces at lists.osgeo.org; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] geotiff image problem
> Sorry for my last post.. I have made a bit of confusion! In the folder
> 'bin' I have found the missed .dll, however I can't understand why does it
> not find it.
> Silvia
> 2008/8/28 Silvia Marchesi <silviamarchesi at gmail.com>
> Thanks a lot,!
> Now I can compile, but when I try to run the program a message appears:
> "This application has failed to start because gdal15d-vc8 was not found.
> Re-installing the application may fix the problem"
> I have checked and in the folder I have downloaded (pre-installed
> gdal151-vc8) there are only gdal_id-vc8.lib and gdal_i-vc8.lib.
> Best regards,
> Silvia
> 2008/8/28 <mchapman at fortifieddatacom.com>
> Silvia,
> In your project properties in vs under the "Link" tab you need to add the
> path to the file "gdal_i.lib".
> Martin
> Sent via BlackBerry by AT&T
> -----Original Message-----
> From: "Silvia Marchesi" <silviamarchesi at gmail.com>
> Date: Thu, 28 Aug 2008 16:30:25
> To: <gdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] geotiff image problem
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080828/7ad73135/attachment.html
