[gdal-dev] probelms with 1.6.0 on Vista 64 bit
Clay, Bruce bclay at ball.com
Mon Dec 8 08:21:30 EST 2008
I am having problems getting GDAL 1.6.0 to work on Vista 64 bit.  It
fails on OgrRegisterAll.  It dose not through an exception it just lets
the program return to the GUI without any error message.  I put a break
point in the error handler call back and it does not hit that either.
It appears to be related to zlib.  I don't have the exact line number
but I was wondering if anyone else has been able to get GDAL 1.6.0 up on
a Vista 64 bit system.
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081208/9670d517/attachment.html
