[gdal-dev] probelms with 1.6.0 on Vista 64 bit
Tamas Szekeres szekerest at gmail.com
Mon Dec 8 08:40:48 EST 2008
Bruce,
Could you describe your test case in more detail? Are you using one of the
console apps of GDAL? Did you compile for x86 or x64?
Best regards,
Tamas
2008/12/8 Clay, Bruce <bclay at ball.com>
>  I am having problems getting GDAL 1.6.0 to work on Vista 64 bit.  It
> fails on OgrRegisterAll.  It dose not through an exception it just lets the
> program return to the GUI without any error message.  I put a break point in
> the error handler call back and it does not hit that either.
> It appears to be related to zlib.  I don't have the exact line number but I
> was wondering if anyone else has been able to get GDAL 1.6.0 up on a Vista
> 64 bit system.
> Bruce
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081208/7abcd794/attachment.html
