[gdal-dev] gdalwarp cutting off projected image
Frank Warmerdam
warmerdam at pobox.com
Tue Dec 9 12:07:51 EST 2008
Scott Lewis wrote:
> Hi,
> I'm fairly new with GDAL, and have been working with a coworker who is a
> little more familiar with GDAL and gdalwarp, but we are both stumped by
> this particular issue.
> I have a GeoTiff image that is in a north polar Lamber Azimuthal Equal
> Area (laea) projection. I am trying to reproject it using gdalwarp to a
> cylindrical projection (like EPSG:4326). I am using the following command:
> gdalwarp -t_srs EPSG:4326 input.gtiff.tif output.gtiff.tif
> The tool runs OK, but when I open output.gtiff.tif, the projection is
> "incomplete". The parts that are there look correct, but it seems
> everything above about 50 degrees is cut off, like the input.gtiff.tif
> had a big circle around 50 degrees cut out before the reprojection was
> made.
> I've tried looking at the options for gdalwarp, but can't seem to find
> anything that would help.
Scott,
There are various challenges in pole (or even dateline) spanning
reprojection operations. The options at:
http://www.gdal.org/structGDALWarpOptions.html#0ed77f9917bb96c7a9aabd73d4d06e08
may be helpful.
In particular, you might try specifying -wo SOURCE_EXTRA=1000 or some similar
large value on the gdalwarp commandline. It is also possible that the
SAMPLE_GRID=YES and SAMPLE_STEPS=100 options might help but generally if
you have lots of RAM and a not-too-big input image specifying a large
SOURCE_EXTRA value will resolve the issues.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
