[gdal-dev] Supporting ECW as a plugin. (Windows)
    Even Rouault
    even.rouault at mines-paris.org
    Tue Dec  9 13:52:29 EST 2008
Just a pointer : http://trac.osgeo.org/gdal/ticket/2320
The GDALRegister_ECW_JP2ECW function is only available in GDAL 1.5.3 or later,
so when using the plugin in http://download.osgeo.org/gdal/win32/1.5/, it's
normal that you don't find the GDALRegister_ECW_JP2ECW entry point.
And, as a reminder, you shouldn't mix plugins between GDAL 1.5.X and GDAL
1.6.0. You should always recompile a plugin version that lies in the GDAL
tree with which you want to use it.
Le Tuesday 09 December 2008 19:16:34 William Kyngesburye, vous avez écrit :
> On Dec 9, 2008, at 11:37 AM, Daniele Romagnoli wrote:
> > When running gdalinfo I get this error:
> >  ERROR 1: Can't find requested entry point: GDALRegister_ECW_JP2ECW
> > Indeed, putting the generated DLL in the "depends/dependency walker"
> > tool, I have only noticed the presence of the following two functions:
> > - GDALRegister_ECW
> > - GDALRegister_JP2ECW
> > whilst the GDALDriverManager:autoLoadDrivers function does:
> > 1) looks for a DLL in the specified GDAL_DRIVER_PATH --->
> > gdal_ECW_JP2ECW.DLL
> > 2) tries to call GDALRegister_ECW_JP2ECW function (missing).
> > The weird thing is that "ecwdataset.cpp" contains that function but
> > the generated DLL doesn't contain it.
> > I have also noticed that the ECW plugin available here
> > (http://download.osgeo.org/gdal/win32/1.5/ ) doesn't contain that
> > registration function.
> > Does anyone already successfully used the ECW as a separated plugin
> > on windows?
> > Am I doing something wrong?
> > Any tips/suggestion would be really appreciated.
> Strange coincidence, or it points to some GDAL bug: I was messing
> around with ECW on OSX as a plugin this weekend.  When I compiled the
> plugin for GDAL 1.6, it loaded.  When I compiled the plugin for GDAL
> 1.5, I got the equivalent error:
> ERROR 1: dlsym(0x10160bd50, _GDALRegister_ECW_JP2ECW): symbol not found
> ERROR 1: dlsym(0x10160bd50, _GDALRegisterMe): symbol not found
> Simply renaming the plugin either gdal_ECW or gdal_JP2ECW works to
> load the driver for the named format.
> Having one as gdal_ECW, then symlinking that to gdal_JP2ECW works to
> load both.  I don't know what the equivalent to symlink is on Windows,
> but duplicating the binary should also work.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly
> disappear and be replaced by something even more bizarrely
> inexplicable.  There is another theory which states that this has
> already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
