[gdal-dev] Supporting ECW as a plugin. (Windows)
William Kyngesburye woklist at kyngchaos.com
Tue Dec 9 14:54:33 EST 2008
On Dec 9, 2008, at 12:52 PM, Even Rouault wrote:
> Just a pointer : http://trac.osgeo.org/gdal/ticket/2320
> The GDALRegister_ECW_JP2ECW function is only available in GDAL 1.5.3
> or later,
> so when using the plugin in http://download.osgeo.org/gdal/
> win32/1.5/, it's
> normal that you don't find the GDALRegister_ECW_JP2ECW entry point.
> And, as a reminder, you shouldn't mix plugins between GDAL 1.5.X and
> GDAL
> 1.6.0. You should always recompile a plugin version that lies in the
> GDAL
> tree with which you want to use it.
I figured that a driver's prototypes would be in the driver's source,
but there I see it in gdal_frmts.h.  So yeah,
GDALRegister_ECW_JP2ECW() really is not going to work in GDAL 1.5.2.
(checking the library symbols, GDALRegister_ECW_JP2ECW() ends up as a C
++ symbol, instead of a C symbol)
I need to update ;)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
