[gdal-dev] Force output color interpretation
Asger Sigurd Skovbo Petersen ASP at blominfo.dk
Thu Dec 11 06:01:26 EST 2008
Hi all,
I'm having problems with the color interpretation of the output from
GDAL utilities. I have some 4 band (Red, Green, Blue, Near infrared)
rasters. The fourth band is interpreted as "Undefined" by GDAL, but GDAL
insists on marking the fourth band as ALPHA in the output. Having the
fourth band marked as ALPHA causes a bunch of problems with other
software, so I would really like the GDAL tools to leave it as
"Undefined". Is this possible?
Please find a simple example below where gdal_translate marks fourth
band as ALPHA.
Best regards
Asger
Example:
c:\>gdalinfo --version
GDAL 1.6.0dev, FWTools 2.2.6, released 2008/08/22
c:\>gdalinfo 2km.tif
Warning 1: TIFFFetchNormalTag:Incompatible type for "RichTIFFIPTC"; tag
ignored
Driver: GTiff/GeoTIFF
Files: 2km.tif
Size is 10000, 10000
Coordinate System is `'
Origin = (580000.000000000000000,6330000.000000000000000)
Pixel Size = (0.200000000000000,-0.200000000000000)
Metadata:
  TIFFTAG_SOFTWARE=Adobe Photoshop CS4 Windows
  TIFFTAG_DATETIME=2008:12:09 17:27:10
  TIFFTAG_XRESOLUTION=72
  TIFFTAG_YRESOLUTION=72
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  580000.000, 6330000.000)
Lower Left  (  580000.000, 6328000.000)
Upper Right (  582000.000, 6330000.000)
Lower Right (  582000.000, 6328000.000)
Center      (  581000.000, 6329000.000)
Band 1 Block=10000x1 Type=Byte, ColorInterp=Red
Band 2 Block=10000x1 Type=Byte, ColorInterp=Green
Band 3 Block=10000x1 Type=Byte, ColorInterp=Blue
Band 4 Block=10000x1 Type=Byte, ColorInterp=Undefined
c:\>gdal_translate 2km.tif out.tif
ignored
Input file size is 10000, 10000
0...10...20...30...40...50...60...70...80...90...100 - done.
c:\>gdalinfo out.tif
Files: out.tif
Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
  Mask Flags: PER_DATASET ALPHA
Band 4 Block=10000x1 Type=Byte, ColorInterp=Alpha
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081211/1c91235d/attachment.html
