[gdal-dev] Intructions to build GDAL for Java
Daniele Romagnoli
dany.geotools at gmail.com
Thu Dec 11 11:52:32 EST 2008
On Wed, Dec 10, 2008 at 7:36 PM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> Hi there,
> I build the Java wrapper a couple of days ago following the instructions on
> [1] but now I need to help someone to
> build for Windows based on [2] but it looks like there was some changes
> that are not reflected on neither one of
> those instructions. For example, there is no more java.opt on the trunk
> [3].
I guess some definitions previously contained on java.opt have been actually
moved on NMAKE.opt in the main gdal folder.
> I tried to run "nmake -f makefile.vc java" on "\swig" anyway but it fails
> and I don't want to expend much time
> debugging since the instructions are outdated.
Can you give me some more detail on the error you have encountered?
Is this error somehow related to ColorTable objects?
In case you can give me the output of your command I can try giving you
better help.
Cheers,
Daniele
> Does anybody have an idea if there are new instructions for building the
> Java wrapper or if it's coming up shortly?
> [1] http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
> [2] http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructions
> [3] http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java
> Regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081211/110a5daf/attachment.html
