[gdal-dev] gdal 1.6 build on redhat Linux, missing gdal.py _gdalmodule.so
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Thu Dec 18 16:11:56 EST 2008
hi list,
I just finished building gdal 1.6 on redhat Linux (using gcc 4.2.2,
python 2.5.2).
After taking Even Rouault and Frank's suggestion, I used the minimized
driver approach. It seemed to work.
  ./configure --prefix=/home/sgong/dev181/dist --with-png=internal
--with-libtiff=internal --with-gif=internal --with-geotiff=internal
--with-libz=/home/sgong/dev181/dist --with-jpeg=/home/sgong/dev181/dist
--with-hdf4=/home/sgong/dev181/dist --with-hdf5=/home/sgong/dev181/dist
--without-ogdi --without-jasper --without-ecw --without-curl
--without-expat --without-dwgdirect --without-mrsid --without-jp2mrsid
--without-mysql --without-odbc --without-grib --without-pg
One question:
After gdal build, the python files: gdal.py, ogr.py, osr.py,
gdalconst.py, gdalnumeric.py did not get copied to
[local_install]/lib/python2.5/site-packages/.  Nor did the
_gdalmodule.a, _gdalmodule.la, _gdalmodule.so,
Did I miss something in config?
thanks,
Shawn
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081218/9a854bcc/attachment.html
