[gdal-dev] gdal 1.6 build on redhat Linux,
missing gdal.py _gdalmodule.so
Klokan Petr Přidal
klokan at klokan.cz
Fri Dec 19 03:08:14 EST 2008
> I just finished building gdal 1.6 on redhat Linux (using gcc 4.2.2, python
> 2.5.2).
> After taking Even Rouault and Frank's suggestion, I used the minimized
> driver approach. It seemed to work.
> ./configure --prefix=/home/sgong/dev181/dist --with-png=internal
> --with-libtiff=internal --with-gif=internal --with-geotiff=internal
> --with-libz=/home/sgong/dev181/dist --with-jpeg=/home/sgong/dev181/dist
> --with-hdf4=/home/sgong/dev181/dist --with-hdf5=/home/sgong/dev181/dist
> --without-ogdi --without-jasper --without-ecw --without-curl --without-expat
> --without-dwgdirect --without-mrsid --without-jp2mrsid --without-mysql
> --without-odbc --without-grib --without-pg
> One question:
> After gdal build, the python files: gdal.py, ogr.py, osr.py, gdalconst.py,
> gdalnumeric.py did not get copied to [local_install]/lib/python
> 2.5/site-packages/. Nor did the _gdalmodule.a, _gdalmodule.la, _gdalmodu
> le.so,
> Did I miss something in config?
I am afraid you missed --with-python ...
Best regards
Klokan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081219/76162051/attachment-0001.html
