[gdal-dev] Convert E00 into Shape
Chris Howell
chowell at pyxisinnovation.com
Sat Feb 9 14:32:55 EST 2008
Ok I am still struggling with the converting of E00 files into shape files. I used avcimport to convert the E00 file into a binary coverage. Now I am trying to use OGR to convert the binary coverage into a shape file. My command looks like.
ogr2ogr.exe -s_srs EPSG:4326 -f "ESRI Shapefile" .\pop .\data\Cov
When I run this command I get the following error message.
ERROR 4 unable to open EPSG support file in gcs.csv
Try setting the GDAL_DATA environment variable to point to the directory containing EPSG csv files - Which I have.
Cheers
Chris
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080209/3bd5b6de/attachment.html
