[gdal-dev] OGR shapefile problems
John C. Tull john.tull at wildnevada.org
Sat Feb 9 17:31:57 EST 2008
Hello All,
I am running into problems with a shapefile using GDAL 1.5 binaries
compiled by William Kyngesburye for OS X Leopard. We are trying to see
if the problem is a GDAL 1.5 issue, or if it is something OS X related.
The file reads properly using pre 1.5 GDAL binaries on OS X and
Ubuntu. I did not have a 1.5 binary on my Ubuntu vm to test. I used
'ogrinfo -al' on the file.
If anyone cares to take a look, I have placed the problem file online.
You can download the landowner shapefile from http://homepage.mac.com/jctull/
Thank you,
John Tull
