[gdal-dev] GDAL and NUTM17 NAD83 datasets.
Collins, Benjamin
collinsb at mitre.org
Tue Feb 12 09:27:22 EST 2008
>-----Original Message-----
>From: Daniele Romagnoli
>As an instance I used gdalinfo from fwtools 2.0.4 on a ECW
>file and I obtained this Coordinate System (partial copy and paste).
>Using "my" gdalinfo I obtain the classic empty string.
Daniele,
Recently I got bit with a similar problem: fwtools (v2.0.x) reported a
projection that my in-house compiled version was not seeing (on a
JP2KAK-driven dataset). In my case there was an ".aux.xml" for the
file. FWTools is compiled with PAM overrides turned on by default,
where the default build from ./configure is not (v1.5.0). One way to
turn this on at runtime for the default build (at least for JP2 w/
Kakadu) is to set the environment variable GDAL_PAM_ENABLED (or
--config option) to YES.
Of course, I have no idea if this is applicable for ECW datasets.
Good luck!
Ben
