[gdal-dev] GDAL and NUTM17 NAD83 datasets.
Daniele Romagnoli dany.geotools at gmail.com
Tue Feb 12 09:32:23 EST 2008
Thx for your tip Ben.
I have replied to myself a minute ago with the solution of my problem :)
1.4.4 looks for a .dat file while 1.5.0 looks for a .wkt file and I'm
linking GDAL_DATA to the bad one...
Regards,
Daniele
On Feb 12, 2008 3:27 PM, Collins, Benjamin <collinsb at mitre.org> wrote:
> >-----Original Message-----
> >From: Daniele Romagnoli
> >As an instance I used gdalinfo from fwtools 2.0.4 on a ECW
> >file and I obtained this Coordinate System (partial copy and paste).
> >Using "my" gdalinfo I obtain the classic empty string.
> Daniele,
> Recently I got bit with a similar problem: fwtools (v2.0.x) reported a
> projection that my in-house compiled version was not seeing (on a
> JP2KAK-driven dataset).  In my case there was an ".aux.xml" for the
> file.  FWTools is compiled with PAM overrides turned on by default,
> where the default build from ./configure is not (v1.5.0).  One way to
> turn this on at runtime for the default build (at least for JP2 w/
> Kakadu) is to set the environment variable GDAL_PAM_ENABLED (or
> --config option) to YES.
> Of course, I have no idea if this is applicable for ECW datasets.
> Good luck!
> Ben
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax:     +39 0584983027
mob:   +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080212/c6a38b4b/attachment.html
