[Gdal-dev] HDF5 root metadata reading in C#
andyNEXT
andrea.pistoni at next.it
Tue Feb 12 10:22:09 EST 2008
Hi All.
I'm trying to read the attributes of an HDF5 file composed as following:
root
+-- S01
+--DS
but I cannot read the attributes (about an hundred) associated to the ROOT
level.
The string code I use in C# is the simple: string[] metadata =
ds.GetMetadata("");
Maybe there is an option of "GetMedata" to read also these metadata.
Thanks in advance.
Regards.
Andrea Pistoni
View this message in context: http://www.nabble.com/HDF5-root-metadata-reading-in-C--tp15434466p15434466.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
