[Gdal-dev] HDF5 root metadata reading in C#
Tamas Szekeres
szekerest at gmail.com
Tue Feb 12 10:42:48 EST 2008
If you are using multiple domains then the domain name should be
specified in the argument of GetMetadata.
Best regards,
Tamas
2008/2/12, andyNEXT <andrea.pistoni at next.it>:
> Hi All.
> I'm trying to read the attributes of an HDF5 file composed as following:
> root
> +-- S01
> +--DS
> but I cannot read the attributes (about an hundred) associated to the ROOT
> level.
> The string code I use in C# is the simple: string[] metadata =
> ds.GetMetadata("");
> Maybe there is an option of "GetMedata" to read also these metadata.
> Thanks in advance.
> Regards.
> Andrea Pistoni
> View this message in context: http://www.nabble.com/HDF5-root-metadata-reading-in-C--tp15434466p15434466.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
