[gdal-dev] ngpython and GetSubDataSets()?
Jose Luis Gomez Dans
josegomez at gmx.net
Tue Feb 12 13:30:03 EST 2008
I've just compiled gdal 1.5.0 on a Linux RHEL5 X86_64 machine. I need to use HDF files extensively, so I've been trying to test whether the new compiled GDAL works. In python, I noticed that I no longer get all the methods I used to get.
In my older version, I had:
In [3]: g=gdal.Open("MOD17A3.A2004366.h19v10.205.2006164124254.hdf")
In [4]: g.Ge
g.GetDescription g.GetGCPCount g.GetGCPs g.GetMetadata g.GetProjectionRef g.GetSubDatasets
g.GetDriver g.GetGCPProjection g.GetGeoTransform g.GetProjection g.GetRasterBand
In [4]: g.GetSubDatasets()
Out[4]:
[('HDF4_EOS:EOS_GRID:"MOD17A3.A2004366.h19v10.205.2006164124254.hdf":MOD_Grid_MOD17A3:Gpp_1km',
'[1200x1200] Gpp_1km MOD_Grid_MOD17A3 (16-bit unsigned integer)'),
('HDF4_EOS:EOS_GRID:"MOD17A3.A2004366.h19v10.205.2006164124254.hdf":MOD_Grid_MOD17A3:Npp_1km',
'[1200x1200] Npp_1km MOD_Grid_MOD17A3 (16-bit integer)'),
('HDF4_EOS:EOS_GRID:"MOD17A3.A2004366.h19v10.205.2006164124254.hdf":MOD_Grid_MOD17A3:Gpp_Npp_QC_1km',
'[1200x1200] Gpp_Npp_QC_1km MOD_Grid_MOD17A3 (8-bit unsigned integer)')]
In the newly-compiled version, I do exactly the same (get a deprecation warning about the osgeo namespace), but when I do g.GetSubDatasets()...
g.GetSubDatasets()
AttributeError Traceback (most recent call last)
/home/ucfajlg/<ipython console>
/usr/lib64/python2.4/site-packages/GDAL-1.5.0-py2.4-linux-x86_64.egg/osgeo/gdal.py in <lambda>(self=<osgeo.gdal.Dataset; proxy of <Swig Object of type 'GDALDatasetShadow *' at 0xbfd3200> >, name='GetSubDatasets')
493 __swig_getmethods__ = {}
494 for _s in [MajorObject]: __swig_getmethods__.update(getattr(_s,'__swig_getmethods__',{}))
--> 495 __getattr__ = lambda self, name: _swig_getattr(self, Dataset, name)
global __getattr__ = undefined
self = <osgeo.gdal.Dataset; proxy of <Swig Object of type 'GDALDatasetShadow *' at 0xbfd3200> >
name = 'GetSubDatasets'
global _swig_getattr = <function _swig_getattr at 0x2aaaaee99050>
global Dataset = <class 'osgeo.gdal.Dataset'>
496 def __init__(self): raise AttributeError, "No constructor defined"
497 __repr__ = _swig_repr
/usr/lib64/python2.4/site-packages/GDAL-1.5.0-py2.4-linux-x86_64.egg/osgeo/gdal.py in _swig_getattr(self=<osgeo.gdal.Dataset; proxy of <Swig Object of type 'GDALDatasetShadow *' at 0xbfd3200> >, class_type=<class 'osgeo.gdal.Dataset'>, name='GetSubDatasets')
32 method = class_type.__swig_getmethods__.get(name,None)
33 if method: return method(self)
---> 34 raise AttributeError,name
global AttributeError = undefined
35
36 def _swig_repr(self):
AttributeError: GetSubDatasets
I solved the problem by getting rid of the /usr/lib64/python2.4/site-packages/GDAL-1.5.0-py2.4-linux-x86_64.egg/ directory, which takes me back to the "oldgen" bindings. My question is whether all the methods from the oldgen bindings have already made it to the ng bindings, or whether there will be other changes that will make my software incompatible when the ng switch goes live, and for which I will need to modify my code.
Cheers,
Jose
Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
