[gdal-dev] Which Linux OS to use when GDAL/OGR is used.
Doug_Newcomb at fws.gov
Wed Feb 20 08:27:39 EST 2008
I've had good luck with Centos 5 . I usually compile form source, but
there are precompiled rpms for gdal 1.4.2 in the Fedora EPEL repositories
, see http://fedoraproject.org/wiki/EPEL , which should work fine for Red
Hat 5 and Centos 5 32 bit and 64 bit. I am not sure which formats are
available with those binaries.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
Life is too short for undocumented, proprietary data formats.
Jeshua Lacock
<jeshua at OpenOSX.c
om> To
Sent by: gdal-dev at lists.osgeo.org
gdal-dev-bounces@ cc
lists.osgeo.org
Subject
Re: [gdal-dev] Which Linux OS to
02/20/2008 07:56 use when GDAL/OGR is used.
AM
On Feb 20, 2008, at 5:15 AM, vdharan nadra wrote:
> We are going to hire a server and going to use GDAL/OGR .Can any one
> help me to select the best one from the following.
> 1. Red Hat enterprise 4
> 2. Red Hat enterprise 5
> 3. Cent OS 4
> 4. Cent OS 5
Greetings,
You might want to consider using Fedora 6, 7, or 8 or Ubuntu 7.04 or
7.10 as there are binaries already compiled at:
<http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries>
Cheers,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
