[gdal-dev] .aux file creation
Michael S. Rosen mrosen at lizardtech.com
Thu Feb 21 13:06:36 EST 2008
Odd.  Is ArcGIS 9.2 is fully Service Packed?  My experience is that 9.2
SP4 reads MrSID projection information correctly.
msr
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
estrada.adam at gmail.com
Sent: Monday, February 18, 2008 7:12 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] .aux file creation
All,
    I have a large amount of MrSID files that were created and are
without the corresponding .aux file.  Even though each MrSID is
properly projected and has the correct map information, ArcGIS (v 9.2)
still does not read it correctly and throws up a warning dialog
stating that there is no spatial reference.  Is there a way to batch
create these files using GDAL?  I see that gdaladdo will create
an .aux file but I belive that this is primarily for pyramid layers
for each image and of course this is not needed for MrSID.
AWE
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
