[gdal-dev] Re: .aux file creation
estrada.adam at gmail.com
Fri Feb 22 14:05:54 EST 2008
Michael,
ArcGIS 9.2 with SP4 fixed the problem.
AWE
On Feb 21, 1:06 pm, "Michael S. Rosen" <mro... at lizardtech.com> wrote:
> Odd. Is ArcGIS 9.2 is fully Service Packed? My experience is that 9.2
> SP4 reads MrSID projection information correctly.
> msr
> -----Original Message-----
> From: gdal-dev-boun... at lists.osgeo.org
> [mailto:gdal-dev-boun... at lists.osgeo.org] On Behalf Of
> estrada.a... at gmail.com
> Sent: Monday, February 18, 2008 7:12 AM
> To: gdal-... at lists.osgeo.org
> Subject: [gdal-dev] .aux file creation
> All,
> I have a large amount of MrSID files that were created and are
> without the corresponding .aux file. Even though each MrSID is
> properly projected and has the correct map information, ArcGIS (v 9.2)
> still does not read it correctly and throws up a warning dialog
> stating that there is no spatial reference. Is there a way to batch
> create these files using GDAL? I see that gdaladdo will create
> an .aux file but I belive that this is primarily for pyramid layers
> for each image and of course this is not needed for MrSID.
> AWE
> gdal-dev mailing list
> gdal-... at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
> gdal-... at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev- Hide quoted text -
> - Show quoted text -
