[gdal-dev] Which Linux OS to use when GDAL/OGR is used.
vdharan nadra
vdharan2001 at gmail.com
Fri Feb 22 01:19:23 EST 2008
Thank You friends for all your suggestions.
Iam planning to go for RHEL 5.
Best Regards,
N.Vidhiyadharan
On Wed, Feb 20, 2008 at 6:22 PM, Frank Warmerdam <warmerdam at pobox.com>
wrote:
> vdharan nadra wrote:
> > HI,
> > We are going to hire a server and going to use GDAL/OGR .Can any one
> > help me to select the best one from the following.
> > 1. Red Hat enterprise 4
> > 2. Red Hat enterprise 5
> > 3. Cent OS 4
> > 4. Cent OS 5
> > Also if i want to use FWTools installer please tell me for which of
> > the above OS it is supported.
> N.Vidhiyadharan,
> GDAL works well on any pretty much any 32bit x86 linux and should work
> fine
> on any of the above. FWTools should also specifically work on any of the
> above. So, you might as well look at other criteria (price, more recent,
> etc).
> I would note that if Debian were trivially available it is nice because
> many GIS packages have been packaged for it by the DebianGIS project.
> But if FWTools has what you need then any of them will do.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080222/17106f03/attachment.html
