R: [gdal-dev] GDAL & Python
Christopher Barker Chris.Barker at noaa.gov
Tue Feb 26 17:59:05 EST 2008
Marco Pasetti wrote:
> Python setup.py -c mingw32 build
> Python -c mingw32 setup.py build
> Python "-c mingw32" setup.py build
> And so on.... But nothing!
SOMETHING must have happened? what errors, etc did you get? (that first
one should be the right one.
Here is a page about building Python extensions on windows with Mingw:
http://boodebr.org/main/python/build-windows-extensions
In there, he suggests:
You now have to tell Python to use the Cygwin/MinGW compiler when
building extensions. To do this, create a file:
  c:\py25\lib\distutils\distutils.cfg:
in it, put:
[build]
compiler = mingw32
Then setup.py build should default to using mingw32
> I'll build GDAL without python bindings... I have no such time to compile
> also python with MinGW!
Being a python fan, I'd like to help with that, but I can't seem to get
GDAL to build at all with mingw and msys. How did you do that? If I can
get GDAL to build, I'll figure out how to get the python extensions to
build.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
