[gdal-dev] netCDF to GRIB 1
John L. Craddock
john.craddock at xitech.com.au
Tue Jan 1 17:12:55 EST 2008
Many thanks for your help Mateusz, I will give it a try.
Regards
John C
> -----Original Message-----
> From: Mateusz Loskot [mailto:mateusz at loskot.net]
> Sent: 02 January 2008 06:43
> To: John L. Craddock
> Cc: gdal
> Subject: Re: [gdal-dev] netCDF to GRIB 1
> Mateusz Loskot wrote:
> > John L. Craddock wrote:
> >> Hello all,
> >> Been scanning the ether for windows code to convert ocean
> current files
> >> in netCDF format to GRIB version 1. I know about GRADS and
> the lats4d
> >> script. Thought I would ask here if anyone knows of a less
> circuitous
> >> way of converting. I see GDAL reads netCDF. Is there a
> driver to output
> >> GRIB?
> > John,
> > There is GRIB driver in the GDAL spike repository:
> > https://svn.osgeo.org/gdal/spike/grib/
> > You may try to checkout it and build into GDAL.
> BTW, here you can find short instructions how to build GDAl with GRIB
> support (the SVN URL given there is not active anymore, use
> the new one
> above):
> http://lists.osgeo.org/pipermail/gdal-dev/2007-February/011663.html
> Mateusz Loskot
> http://mateusz.loskot.net
