[gdal-dev] netCDF to GRIB 1
Bas Retsios retsios at itc.nl
Mon Jan 7 12:20:45 EST 2008
Hello,
The GDAL-GRIB driver mentioned will read GRIB files (not write them),
therefore it can not be directly used for converting netCDF to GRIB files.
However, this information might help:
For saving time when I was working on this driver, I implemented it as a
"wrapper" around a full GRIB library written by Mr. Arthur Taylor.
The SVN link below contains both the "wrapper" that gives GDAL
"GRIB-read" capabilities (which is file gribdataset.cpp), and the full
GRIB library (which is all other files).
The GRIB library can both read and write GRIB files, but I only called
the functions for reading (because that is what I was interested in).
With some effort you would be able to extend gribdataset.cpp so that it
can also write back a GRIB file. This link
http://www.gdal.org/gdal_drivertut.html describes how to proceed, at
section "File Creation".
Cheers,
Bas.
Ir. V. (Bas) Retsios
Software Developer
Geo-information Processing Department
International Institute for Geo-information Science and Earth Observation (ITC)
P.O. Box 6,  7500 AA Enschede, The Netherlands
Phone +31 (0)53 4874 573, telefax +31 (0)53 4874 335
E-mail retsios at itc.nl, Internet http://www.itc.nl
John L. Craddock wrote:
>Many thanks for your help Mateusz, I will give it a try.
>Regards
>John C
>>-----Original Message-----
>>From: Mateusz Loskot [mailto:mateusz at loskot.net]
>>Sent: 02 January 2008 06:43
>>To: John L. Craddock
>>Cc: gdal
>>Subject: Re: [gdal-dev] netCDF to GRIB 1
>>>>Hello all,
>>>>Been scanning the ether for windows code to convert ocean
>>current files
>>>>in netCDF format to GRIB version 1. I know about GRADS and
>>the lats4d
>>>>script. Thought I would ask here if anyone knows of a less
>>circuitous
>>>>way of converting. I see GDAL reads netCDF. Is there a
>>driver to output
>>>>GRIB?
>>>John,
>>>There is GRIB driver in the GDAL spike repository:
>>>https://svn.osgeo.org/gdal/spike/grib/
>>>You may try to checkout it and build into GDAL.
>>BTW, here you can find short instructions how to build GDAl with GRIB
>>support (the SVN URL given there is not active anymore, use
>>the new one
>>above):
>>http://lists.osgeo.org/pipermail/gdal-dev/2007-February/011663.html
>>Mateusz Loskot
>>http://mateusz.loskot.net
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080107/41293e1a/attachment.html
