[gdal-dev] oci and sde drivers not registered
Clay, Bruce bclay at ball.com
Wed Jan 2 11:18:21 EST 2008
I am having problems getting to the OCI and SDE drivers loaded.
I initially pulled the FWTools.2.0.4 download then I downloaded the
precompiled OCI and SDE drivers from http://download.osgeo.org/gdal/.
When I execute ogrinfo -formats I see 26 drivers that were in the
initial configuration from FWTools.  I put the OCI and SDE dll's in the
FWTools.2.0.4/bin directory where the ogrinfo executable resides and I
added MSVCP71D.dll and MSVCR71D.dll because I received 2 errors while
running ogrinfo when it tried to load the ogr_SDE.dll.
Since I got the error while trying to load the load the SDE driver
before adding the dll's. I rashly assume that OGR recognizes the driver.
Is there some other step I need to take to get these last 2 drivers
registered?
Is there anything else I will have to do once ogrinfo sees the drivers
since I am using the C# wrapper in my code?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080102/f32973d3/attachment.html
