[gdal-dev] wkbFlatten in tutorial
Frank Warmerdam
warmerdam at pobox.com
Sat Jan 5 11:57:16 EST 2008
Ben Discoe wrote:
> In the OGR tutorial here:
> http://www.gdal.org/ogr/ogr_apitut.html
> I find the text:
> "For each 2D geometry type there is a corresponding 2.5D type code; however, there is only a C++ class for both the 2D and 3D cases."
> I can't quite parse it. I understand that wkbFlatten turns e.g. wkbLineString25D into wkbLineString, and that the class OGRLineString stores either type. Perhaps the tutorial means to say "there is NOT a C++ class.."?
Ben,
I have adjusted this text as follows, which is hopefully less mixed up
and confusing.
The wkbFlatten() macro is used above to convert the type for a wkbPoint25D
(a point with a z coordinate) into the base 2D geometry type code (wkbPoint).
For each 2D geometry type there is a corresponding 2.5D type code. The 2D
and 2.5D geometry cases are handled by the same C++ class, so our code will
handle 2D or 3D cases properly.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
