[gdal-dev] more OGR problems
Clay, Bruce bclay at ball.com
Mon Jan 7 15:28:22 EST 2008
I am trying several different things to get my application to read data
from an Oracle Spatial table and still can not come up with a solid
solution.
I have tried ODBC but can not get it to connect to the table.  My
application usually hangs on the ogr.open() statement.  I have tried
"ODBC:username/password at instanceName", but I get an error that the
driver is not specified.  I have also tried "ODBC:{Microsoft ODBC for
Oracle};Server=instance;UID=userName;PWD=password;". This one hangs as
does any others when I specify a driver.
I have tried OCI and can get connected but it only shows a few tables in
the whole database.  It only shows those with SDO metadata set.
I can retrieve data from the table with the exception of date values.  I
can use the DateTime field in the query itself and it seems to work ok
but I can not return the actual date.
I can get the index to the "SHAPE" and IsFieldSet returns true but
geometry = feature.GetGeometryDef() always returns NULL.
I can connect using the SDE driver but I get an odd error when I issue
the same SQL that works with the OCI driver.  The error is "Could not
execute SQL statement\nSQL: Syntax error, 14 extra tokens".  When I use
the SDE driver I see all of the tables and all of the fields in the
tables.
For some reason I can not use the debugger to step into any of the GDAL
/ OGR code.  I don't know if it is because of the managed vs. unmanaged
code since my app is written in C# or if it is the SWIG bindings.
Either way I am flying blind.
I keep hoping if that someone out there has run across some of these
problems and can give me a clue or something to try.  I would like to
ditch C# but that is not an option at this point.
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080107/61152817/attachment.html
