[gdal-dev] Compiling GDAL 1.5 with Proj.4.6: proj_i.lib is missingall the time
Kolberg Sjur A Sjur.A.Kolberg at sintef.no
Thu Jan 10 03:04:29 EST 2008
Oops,
The CR/LF's in the file I copied in disappeared in the mail.
The export function names should be on separate lines.
Also, all semicolons start a new line.
The .def file again:
; R.def : Export function list from R 2.6.0
; Generated using DUMPBIN /EXPORTS /OUT:R.def R.dll and editing.
; This file in used to create R.lib using LIB /def:r.def /out:r.lib
; DUMPBIN.EXE and LIB.EXE reside in C:\Program Files\Microsoft Visual
Studio 8\VC
LIBRARY      "R"
; DESCRIPTION  'R 2.6.0 Dynamic Link Library'
EXPORTS
     ; This is the list of exported function names
ATTRIB
AllDevicesKilled
BODY
Brent_fmin
CAAR
CAD4R
CADDDR
CADDR
...etc. There is no keyword or other signal at the end.
> > -----Original Message-----
> > From: gdal-dev-bounces at lists.osgeo.org
> > [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Tom Kazimiers
> > Sent: 10 januar 2008 01:51
> > To: GDAL-Mailinglist
> > Subject: [gdal-dev] Compiling GDAL 1.5 with Proj.4.6:
> > Hello,
> > allday I tryed to get GDAL 1.5 working with Proj.4 (4.6) -
> without any
> > luck.
> > Sure I am compiling for WinCE but this changes not that
> much, does it?
> > After fixing some things with missing files (pj_eqr,
> pj_glabgsm, ...)
> > everything works well until proj_i.lib should be linked to
> GDAL - this
> > does not work since proj_i.lib is never created. Did you experience
> > this problem, too or do you have any ideas how to solve it? I tryed
> > manually using LIB - without success.
> > Thank you very much
> > Tom
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
