[gdal-dev] divide by zero errors
LeRetha Childress leretha.childress at baronservices.com
Thu Jan 17 15:02:35 EST 2008
I am using gdal in FWTools2.0.4
I have been processing some files from
ftp://ftpprd.ncep.noaa.gov/pub/data/nccf/com/gfs/prod/ in various formats
such as rucs, nam, gfs etc.
I have encountered a problem with files that end with .grib2
For example if I run
gdalinfo -mm gdas1.t00z.engicegrb.grib2
it starts processing and then stops at band 1
when debugged I get the following message
            Unhandled exception at 0x10049e24 in gdalinfo.exe : 0xC0000094.
            Integer division by zero.
Has anyone else encountered this problem?
Or can anyone tell me what to do to get gdal to process these files?
Thanks
LeRetha Childress
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080117/a640c1c0/attachment.html
