[gdal-dev] Re: GDAL 1.5.0 Perl Binding on Cygwin
Paul Mallas
pmallas at rsmas.miami.edu
Thu Jan 24 09:56:07 EST 2008
I fixed this problem by editing a Cygwin script /usr/bin/perlld from:
my $CC = 'gcc';
to:
my $CC = 'g++';
This seems to fix other perl problems (non-GDAL) with Cygwin as well.
When I pointed this out, the Cygwin folks thought it was a bug but
wanted to investigate why this was set to gcc in the first place.
Anyway, my problem remains with perl swig bindings on Cygwin. I know Ari
wants nothing more to do with this issue, but since we're on the
subject, maybe someone else might able to give me a clue.
It seems I have a problem linking with the gdal lib with external libs.
I get a ton of these types of messages below - I think the issue has
to do with the beginning underscore in the calls because rikdataset.cpp
calls "uncompress" not "_uncompress":
/usr/local/lib/libgdal.a(rikdataset.o):rikdataset.cpp:(.text+0x519):
undefined reference to `_uncompress'
/usr/local/lib/libgdal.a(jpeg2000dataset.o): In function
`_ZN18JPEG2000RasterBandC2EP15JPEG2000Datasetiii':
/home/pmallas/gdal/frmts/jpeg2000/jpeg2000dataset.cpp:257: undefined
reference to `_jas_matrix_create'
I am ignorant of how libraries get called - probably the windows demands
a prepended underscore for library calls or something. And I know there
are flags to manipulate leading underscores with g++ (like
-fleading-underscore), but I could never get them to work. I have spent
considerable time trying to sort this out with no luck.
Any insights would be appreciated.
jingmuyang at aol.com wrote:
> I have successfully built GDAL 1.5.0 Perl binding on Cygwin and the
> followings might be helpful for those who experience problems.
> 1. Go to directory gdal-1.5.0/swig/perl and run 'perl Makefile.PL'. The
> following four Makefiles should be created if it succeeds:
> Makefile_Geo__GDAL
> Makefile_Geo__GDAL__Const
> Makefile_Geo__OGR
> Makefile_Geo__OSR
> 2. Edit each of the four Makefiles by appending -lstdc++ after each
> -lgdal and save them.
> 3. Run make using each of the four Makefiles as follows:
> make -f Makefile_Geo__GDAL
> make -f Makefile_Geo__GDAL__Const
> make -f Makefile_Geo__OGR
> make -f Makefile_Geo__OSR
> 4. Install the Perl Geo::GDAL package by running
> make -f Makefile_Geo__GDAL install
> That it. Enjoy!
> Jim
> More new features than ever. Check out the new AOL Mail
> <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
