[gdal-dev] Re: GDAL 1.5.0 Perl Binding on Cygwin
Jingmu Yang jingmuyang at aol.com
Thu Jan 24 19:36:05 EST 2008
I experienced the same problem when I initially built GDAL 1.5.0 on
Cygwin.  After analyzing the libraries I found that I had old GDAL
libraries installed on /usr/local/lib/.  What I did was to delete those
old libraries from /usr/local/lib and then built GDAL 1.5.0 without Perl
binding.  After GDAL 1.5.0 was installed on /usr/local/ I built Perl
binding as I described and I no longer have the link problems.
Hope this can help.
Jim
Paul Mallas wrote:
> I fixed this problem by editing a Cygwin script /usr/bin/perlld from:
> my $CC = 'gcc';
> to:
> my $CC = 'g++';
> This seems to fix other perl problems (non-GDAL) with Cygwin as well.
> When I pointed this out, the Cygwin folks thought it was a bug but
> wanted to investigate why this was set to gcc in the first place.
> Anyway, my problem remains with perl swig bindings on Cygwin. I know
> Ari wants nothing more to do with this issue, but since we're on the
> subject, maybe someone else might able to give me a clue.
> It seems I have a problem linking with the gdal lib with external
> libs.  I get a ton of these types of messages below - I think the
> issue has to do with the beginning underscore in the calls because
> rikdataset.cpp calls "uncompress" not "_uncompress":
> /usr/local/lib/libgdal.a(rikdataset.o):rikdataset.cpp:(.text+0x519):
> undefined reference to `_uncompress'
> /usr/local/lib/libgdal.a(jpeg2000dataset.o): In function
> `_ZN18JPEG2000RasterBandC2EP15JPEG2000Datasetiii':
> /home/pmallas/gdal/frmts/jpeg2000/jpeg2000dataset.cpp:257: undefined
> reference to `_jas_matrix_create'
> I am ignorant of how libraries get called - probably the windows
> demands a prepended underscore for library calls or something. And I
> know there are flags to manipulate leading underscores with g++ (like
> -fleading-underscore), but I could never get them to work. I have
> spent considerable time trying to sort this out with no luck.
> Any insights would be appreciated.
> jingmuyang at aol.com wrote:
>> I have successfully built GDAL 1.5.0 Perl binding on Cygwin and the
>> followings might be helpful for those who experience problems.
>> 1. Go to directory gdal-1.5.0/swig/perl and run 'perl Makefile.PL'.
>> The following four Makefiles should be created if it succeeds:
>> Makefile_Geo__GDAL
>> Makefile_Geo__GDAL__Const
>> Makefile_Geo__OGR
>> Makefile_Geo__OSR
>> 2. Edit each of the four Makefiles by appending -lstdc++ after each
>> -lgdal and save them.
>> 3. Run make using each of the four Makefiles as follows:
>> make -f Makefile_Geo__GDAL
>> make -f Makefile_Geo__GDAL__Const
>> make -f Makefile_Geo__OGR
>> make -f Makefile_Geo__OSR
>> 4. Install the Perl Geo::GDAL package by running
>> make -f Makefile_Geo__GDAL install
>> That it.  Enjoy!
>> Jim
>> More new features than ever. Check out the new AOL Mail
>> <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>!
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
