[gdal-dev] ERDAS Imagine to ERMapper
nicholas.g.lawrence at mainroads.qld.gov.au
Thu Jan 24 18:01:43 EST 2008
Hello,
I have a large (19 Gigabyte) erdas imagine file which I want to bring into
ERMapper.
I have downloaded the minimalist windows executables from
http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
I am running windows xp with 2 GB of RAM.
I know I should use the gdal_translate command, but I am unsure of the best
output format.
ecw won't work for the file size is too large.
I thought GTiff would work, but I can't force BIGTIFF=YES
Is there a plain old band-interleaved-by-line format available?
Regards,
nick
WARNING: This e-mail (including any attachments) may contain legally
privileged, confidential or private information and may be protected by
copyright. You may only use it if you are the person(s) it was intended
to be sent to and if you use it in an authorised way. No one is
allowed to use, review, alter, transmit, disclose, distribute, print
or copy this e-mail without appropriate authority.
If this e-mail was not intended for you and was sent to you by mistake,
please telephone or e-mail me immediately, destroy any hardcopies of
this e-mail and delete it and any copies of it from your computer
system. Any right which the sender may have under copyright law, and
any legal privilege and confidentiality attached to this e-mail is not
waived or destroyed by that mistake.
It is your responsibility to ensure that this e-mail does not contain
and is not affected by computer viruses, defects or interference by
third parties or replication problems (including incompatibility with
your computer system).
Opinions contained in this e-mail do not necessarily reflect the
opinions of the Queensland Department of Main Roads, Queensland
Transport or Maritime Safety Queensland, or endorsed organisations
utilising the same infrastructure.
