[gdal-dev] ERDAS Imagine to ERMapper
Norman Barker nbarker at ittvis.com
Thu Jan 24 18:10:09 EST 2008
ERMapper supports jpeg2000 and whilst you can't convert to jpeg2000
using the gdal jp2ecw driver (since the driver is limited to 500mb not
ERMapper) you can with JP2KAK
So,
gdal_translate -OF JP2KAK in.img out.jp2
but it might take a while ....
Norman
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
nicholas.g.lawrence at mainroads.qld.gov.au
Sent: Thursday, January 24, 2008 4:02 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] ERDAS Imagine to ERMapper
Hello,
I have a large (19 Gigabyte) erdas imagine file which I want to bring
into
ERMapper.
I have downloaded the minimalist windows executables from
http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
I am running windows xp with 2 GB of RAM.
I know I should use the gdal_translate command, but I am unsure of the
best
output format.
ecw won't work for the file size is too large.
I thought GTiff would work, but I can't force BIGTIFF=YES
Is there a plain old band-interleaved-by-line format available?
Regards,
nick
WARNING: This e-mail (including any attachments) may contain legally
privileged, confidential or private information and may be protected by
copyright. You may only use it if you are the person(s) it was intended
to be sent to and if you use it in an authorised way.  No one is
allowed to use, review, alter, transmit, disclose, distribute, print
or copy this e-mail without appropriate authority.
If this e-mail was not intended for you and was sent to you by mistake,
please telephone or e-mail me immediately, destroy any hardcopies of
this e-mail and delete it and any copies of it from your computer
system. Any right which the sender may have under copyright law, and
any legal privilege and confidentiality attached to this e-mail is not
waived or destroyed by that mistake.
It is your responsibility to ensure that this e-mail does not contain
and is not affected by computer viruses, defects or interference by
third parties or replication problems (including incompatibility with
your computer system).
Opinions contained in this e-mail do not necessarily reflect the
opinions of the Queensland Department of Main Roads, Queensland
Transport or Maritime Safety Queensland, or endorsed organisations
utilising the same infrastructure.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
