[gdal-dev] Gdaladdo error
Coutu, Jean-François COUTUJF at dfo-mpo.gc.ca
Thu Jan 24 20:48:32 EST 2008
I am trying to build overviews for 100+ geotiff and tiff files.
Gdaladdo only screws up on a handful.
Can anyone tell me what is wrong with my files?
I have: GDAL 1.5.0b1, FWTools 2.0.3, released 2007/12/10
Here is the error I get:
gdaladdo -r average 1965_04_07_Prince_Rupert_PK00893_PK05204.TIF 2 4 8 16
0...10...20...30...40...50...60...70...80...90...100 - done.
Assertion failed: tif->tif_flags&TIFF_BIGTIFF, file tif_dirwrite.c, line 2027
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Here is gdalinfo output before and after:
Driver: GTiff/GeoTIFF
Files: 1965_04_07_Prince_Rupert_PK00893_PK05204.TIF
       1965_04_07_Prince_Rupert_PK00893_PK05204.aux
Size is 7800, 12100
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-129],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26909"]]
Origin = (416530.000000000000000,6021255.000000000000000)
Pixel Size = (0.100000000000000,-0.100000000000000)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_IMAGEDESCRIPTION=ORTHO: LL XY: 416530.000 6020045.000 PIXELS: 0.10 0.10 ROT: 0.00
  TIFFTAG_SOFTWARE=Adobe Photoshop CS Windows
  TIFFTAG_DATETIME=2007:08:28 22:22:19
  TIFFTAG_XRESOLUTION=72
  TIFFTAG_YRESOLUTION=72
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  416530.000, 6021255.000) (130d17'1.20"W, 54d19'56.30"N)
Lower Left  (  416530.000, 6020045.000) (130d16'59.98"W, 54d19'17.17"N)
Upper Right (  417310.000, 6021255.000) (130d16'18.03"W, 54d19'56.76"N)
Lower Right (  417310.000, 6020045.000) (130d16'16.82"W, 54d19'17.62"N)
Center      (  416920.000, 6020650.000) (130d16'39.01"W, 54d19'36.96"N)
Band 1 Block=7800x1 Type=Byte, ColorInterp=Gray
  Metadata:
    LAYER_TYPE=athematic
<GDALRasterAttributeTable/>
After:
ERROR 1: 1965_04_07_Prince_Rupert_PK00893_PK05204.TIF:No space to read TIFF dire
ctory
ERROR 1: TIFFReadDirectory:Failed to read directory at offset 127257924
gdalinfo failed - unable to open '1965_04_07_Prince_Rupert_PK00893_PK05204.TIF'.
Thanks!
Jean-Francois Coutu
Canadian Coast Guard
coutujf at dfo dash mpo dot gc dot ca
"The fate of the Universe is a decision yet to be made, one which we will intelligently consider when the time is right"  -R. Kurzweil
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080124/c2355bc3/attachment.html
